Joined: 1/8/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
Howdy All,
I have an ongoing problem with the Samsung WF45K6200AW/A2 Front Loader Washer where it goes to a cycle and after running water and sensing load it drops to a 4C Error.
Water is ON, hoses are NOT kinked or coiled tightly, they are run water in a bucket just perfectly at a good flow pressure.
What I have done so far: I have cleaned the filter on the Cold and Hot water intake - No Change
I have cleaned the drain/pump filter - No Change
I have replaced the valve assembly for cold water - No Change
What I am seeing;
It will trigger the cold water valve that goes to the "Pre Wash" detergent assembly and the water will run while the motor spins and it senses load. After a few minutes it will error out to " 4C " and then run the drain/
If water is set to HOT, it will still only trigger the cold water valve that goes to the "Pre Wash" detergent assembly and the water will run while the motor spins and it senses load. After a few minutes it will error out to " 4C " and then run the drain/
I am not sure what else to do.
