Visualist
#1 Posted : Tuesday, December 28, 2021 9:16:05 AM(UTC)
Visualist
United States
I'm getting a pyramid of ice under the ice maker on the metal plate directly under the fill pipe. The water isn't leaking evenly across the ice maker as though it was overflowing.
I noticed the replacement fill-pipe assembly has a longer fill tube. Could this be the problem. I believe this was made in 2016.
Thank you.
Ice in Freezer
cfaber
#2 Posted : Tuesday, December 28, 2021 9:32:28 AM(UTC)
cfaber
Sounds like the solenoid valve which controls water flow into the ice maker is leaking. It's an easy fix.
Visualist
#3 Posted : Tuesday, December 28, 2021 10:29:11 AM(UTC)
Visualist
United States
I'll try that. Thanks!
I should also note that the leaking occurred during the filling of the ice maker.
Edited by user Tuesday, December 28, 2021 10:39:09 AM(UTC)  | Reason: Clarification
