I'm getting a pyramid of ice under the ice maker on the metal plate directly under the fill pipe. The water isn't leaking evenly across the ice maker as though it was overflowing. I noticed the replacement fill-pipe assembly has a longer fill tube. Could this be the problem. I believe this was made in 2016. Thank you.
Sounds like the solenoid valve which controls water flow into the ice maker is leaking. It's an easy fix.
I'll try that. Thanks! I should also note that the leaking occurred during the filling of the ice maker. Edited by user Tuesday, December 28, 2021 10:39:09 AM(UTC)
| Reason: Clarification
