Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I HAVE JENN-AIR MODELJGM8130DDM GAS SLIDE IN OVEN APPX. 20 YEARS OLD THE OVEN STARTED SHUTTING OFF BY IT'S SELF FOR 6 MONTHS DIAGNOSIS WAS CONTROL MODULE HAD FAILED NOTHING OPERATING BLANK SCREEN PURCHASED NEW MODULE CLOCK WORKED AS NORMAL LIGHTING UP OVEN TURNS ON BUT WHEN TEMPERATURE REACHES 175 DEGREES OVEN GOES OFF, SCREEN GOES BLANK AND TICHING NOISE STARTS HIT CANCEL AND STARTS TO RESTORE PANEL LIGHT TURNS BACK ON THE BROILER WORKS PERFECT WITH BOTH TEMPERATURE SETTINGS WORK AND WORKS UP TO 500 DEGREES AND WORKS PERFECT THE OVEN BAKE IGHNIGHTER HAS BEEN REPLACED AND WORKS LIKE NEW THE TEMPERATURE WAS REPLACED THE OVEN COOK CYCLE IS STILL THE ONLY PROBLEM SHUTTING OFF I BELIEVE WE CHECKED THE OHM RANGE AND IT WAS NEAR PERFECT THE FIRM I PURCHASED THE CONTROL MODULE FROM WILL REPLACE THE CONTROL MODULE HOWEVER IT APPEARS THEY CANNOT GET ANOTHER BECAUSE THEY ARE NO LONGER BEING MADE THE OVEN LOOKS LIKE NEAR NEW AND DO NOT WANT TO THROW IT AWAY ANY SUGGESTIONS SEVERAL RELIABLE SOURCES SUGGESTED THE REBUILT CONTROL MODULE MAY BE THE PROBLEM 916 849-2384 EMAIL PMCS73@YAHOO.COM
