GuestJ OHN CARGILE
#1 Posted : Sunday, November 21, 2021 5:35:44 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
I HAVE JENN-AIR MODELJGM8130DDM GAS SLIDE IN OVEN APPX. 20 YEARS OLD
THE OVEN STARTED SHUTTING OFF BY IT'S SELF FOR 6 MONTHS
DIAGNOSIS WAS CONTROL MODULE HAD FAILED NOTHING OPERATING BLANK SCREEN
PURCHASED NEW MODULE CLOCK WORKED AS NORMAL LIGHTING UP
OVEN TURNS ON BUT WHEN TEMPERATURE REACHES 175 DEGREES OVEN GOES OFF, SCREEN GOES BLANK AND TICHING NOISE STARTS
HIT CANCEL AND STARTS TO RESTORE PANEL LIGHT TURNS BACK ON
THE BROILER WORKS PERFECT WITH BOTH TEMPERATURE SETTINGS WORK AND WORKS UP TO 500 DEGREES AND WORKS PERFECT
THE OVEN BAKE IGHNIGHTER HAS BEEN REPLACED AND WORKS LIKE NEW
THE TEMPERATURE WAS REPLACED
THE OVEN COOK CYCLE IS STILL THE ONLY PROBLEM SHUTTING OFF
I BELIEVE WE CHECKED THE OHM RANGE AND IT WAS NEAR PERFECT
THE FIRM I PURCHASED THE CONTROL MODULE FROM WILL REPLACE THE CONTROL MODULE HOWEVER IT APPEARS THEY CANNOT GET ANOTHER BECAUSE THEY ARE NO LONGER BEING MADE
THE OVEN LOOKS LIKE NEAR NEW AND DO NOT WANT TO THROW IT AWAY
ANY SUGGESTIONS SEVERAL RELIABLE SOURCES SUGGESTED THE REBUILT CONTROL MODULE MAY BE THE PROBLEM
916 849-2384 EMAIL PMCS73@YAHOO.COM
