Jricea
#1 Posted : Monday, November 15, 2021 9:24:27 AM(UTC)
Jricea
United States
For the past few months months my Samsung oven
hasn't been heating properly. It may get to temperature
eventually but will drop below or not heat at all. I've
noticed that if I put pressure on the control panel that I
can hear the relays popping and sometimes buzzing
as I apply pressure.
I removed the rear cover of the oven today and noticed
that the plug to the DLB relay is browned as if it's been
burning a bit.
Would I need to replace the circuit board or wiring
harness in this case?
Thanks in advance!
[img]https://ibb.co/MMvGbHR[/img]
