For the past few months months my Samsung oven hasn't been heating properly. It may get to temperature eventually but will drop below or not heat at all. I've noticed that if I put pressure on the control panel that I can hear the relays popping and sometimes buzzing as I apply pressure.
I removed the rear cover of the oven today and noticed that the plug to the DLB relay is browned as if it's been burning a bit.
Would I need to replace the circuit board or wiring harness in this case?
Thanks in advance!
[img]https://ibb.co/MMvGbHR[/img]
