Guest
#1 Posted : Tuesday, September 28, 2021 12:47:19 PM(UTC)
Guest
Rank: Guest
United States
I have watched all the videos and I’m at a loss so turning to you all for help.
I have a GE dishwasher that has no error codes will run through a full cycle filling with water and draining properly heating properly but not washing completely. Intermittently the pump will run and spray. I have remove the pump to check for debris and it runs freely and as I would describe very good. I have bench tested with 120 V and all seems OK.
No other obvious symptoms.
I have cleaned everything there is to clean.
PCB?
