AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
GE dishwasher not cleaning- pump okay, but not fully spraying
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have watched all the videos and I’m at a loss so turning to you all for help. I have a GE dishwasher that has no error codes will run through a full cycle filling with water and draining properly heating properly but not washing completely. Intermittently the pump will run and spray. I have remove the pump to check for debris and it runs freely and as I would describe very good. I have bench tested with 120 V and all seems OK. No other obvious symptoms. I have cleaned everything there is to clean. PCB?
Dishwasher Repair
