b707guy
#1 Posted : 4 years ago
b707guy
Hello, I have a GE PDW8280N00SS. Until recently, it's worked like a champ since installing it in 2007. However, it has begun to not clean upper rack items or the silverware on the bottom rack. No change in loading technique.
When opening the door during the fill cycle, there is very little water in the basin, and the fill port only has a small amount of water trickling out (not sure how quickly it might shut off when the door is sensed not closed). The fill cycle ends in less than a minute. A sticker on the fill valve mentions a three-minute timer. Not sure what would cause the timer to shut off in less than three minutes, unless the door is opened or the flood switch interrupts it. The filter screen built in to the fill valve is clean. The valve itself appears to be working, as it opens and closes on command. The flood switch and float are working fine.
There is zero clogging of any of the other filters or their assemblies, drain system works fine, water pressure at the shutoff valve under the sink is great, and the spray arm jets are clean. However, water pressure coming out of the inlet hose at the fill valve seems very low. I am using a "FloodSafe" water supply hose. A label on the hose says to disconnect and reconnect to reset the hose, but it is not shut off - simply very low flow when compared with a non-FloodSafe hose.
If I add water to the basin, everything seems to work fine, with water audibly hitting the door from the upper spray arms and with the spray arms re-positioned and with water dripping from them upon opening the door mid cycle.
So it seems the issue is that there isn't enough water entering the machine. I'm guessing the likely causes for that might be:
1. Fill valve (part 744) not opening fully or shutting off too early for some reason?
2. FloodSafe supply hose between household shutoff valve and fill valve clogged?
3. Clog in the fill hose (part 576) between the fill valve and the inlet cover (573)/fill funnel (575)? I haven't pulled the machine from under the cabinet to assess this possibility.
4. Other?
Appreciate any insight on narrowing down a cause - hate to just throw money/parts at it hoping something works!
P.S. I did read the 10-y/o sticky post about the Frigidaire with similar problem, but no solution seems to have worked, other than perhaps the OP getting either a new dishwasher (or a new wife!).
Edited by user 4 years ago  | Reason: Not specified
b707guy
#2 Posted : 4 years ago
b707guy
Originally Posted by: ohm Go to Quoted Post
Do not use a flood safe hose on a dishwasher at all or a washing machine. Thats a bad idea as the design of the hoses can set off the flood part.LOL
After reading a number of poor reviews of the FloodSafe hoses, I think I'll try a good old fashioned braided hose first. Still doesn't explain why the three-minute fill valve would shut off after less than a minute when the machine clearly has insufficient water, but if the replacement hose doesn't do the trick, then I'll try a new fill valve.
b707guy
#3 Posted : 4 years ago
b707guy
Well, as with so many problems in life, it's thankfully the simplest thing that fixed it. Replaced the FloodSafe hose with a standard braided hose, and it's working great. Wife was getting anxious for a new dishwasher, which, of course, also leads to a new fridge. Then an oven, microwave, etc, because, you know, they have to match! But that's another problem... :)
