Per the online selection guide, I ordered WP3149404 for my KERA205PSS2, but the stem is too long and the knob sticks out further than the rest. Please advise the correct part number I should order for this 6" burner control. This KitchenAid range serial number is RS3919755. Thanks! Edited by user Sunday, July 18, 2021 9:45:18 AM(UTC)
| Reason: corrected part number
Groups: Expert
If the shaft is too long, you can shorten it. look at this picture. https://cdn.appliancepar...49404-ap6007668_02_l.jpgSee the narrow area of the shaft? You can remove the spring steel knob retainer and using two pair of pliers, snap the top off the shaft. Then reinstall the knob retainer on the lower part of the shaft.
