Model: YKERA205PS3 Brand: Kitchenaid
Part replaced: 9757030 (old and new part numbers match)
I replaced the infinite switch for the both the dual elements as the old ones were stuck on high. I took pictures and wired them the same. However, the 'single' and 'dual' knob rotation directions are reversed from what they used to be. Turning it to dual heats up the inner element and turning it to single heats up both elements.
S1 - black P2 - black 2 - orange solid 4 - orange with black stripe 4a - orange with white stripe S2 - violet P1 - two wires, red with white stripe
I tried swapping '4' and '4a'. 'Single' heats up both elements. 'Dual' heats up the outer element only.
Do I need to wire the switch differently?
