Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Dreyer runs and tub rotates, timer works, no heat. Removed heater and tested the heating element at 5 ohms, from what I read here any continuity represents a good element. Also tested both fuses and both have 0 ohm continuity. Test good. Removed the high temp thermostat switch and it tested a 0 ohms. I couldn't find test procedures for it on site. If this unit is normally open and trips to closed then it is likely the culprit. If this switch is normally closed and fails open then I'm stumped at where to look for the problem. Please help... Edited by user Saturday, May 1, 2021 3:48:58 PM(UTC)
| Reason: Not specified
Rank: Guest
Groups: Guests
Also tested the centrifugal switch in the motor and it was good. Found testing procedures for the HT Thermostat and that tested good as well. UGH!!!
