Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
About 5 minutes into the Wash cycle, the dishwasher stopped. The Cancel and Normal LEDs began flashing continually. I was unable to get the Cancel/Drain to work, so I had to remove the water from inside the dishwasher. There is no reset on this model. In the past, when the Cancel and Normal LEDs were flashing, I would let it sit for 48-72 hours and it would stop flashing the LEDs. That hasn't worked this time. Does anyone know what I should check to see what is causing the problem?
