Guest
#1 Posted : Thursday, March 25, 2021 6:39:10 PM(UTC)
Guest
Rank: Guest
United States
About 5 minutes into the Wash cycle, the dishwasher stopped. The Cancel and Normal LEDs began flashing continually.
I was unable to get the Cancel/Drain to work, so I had to remove the water from inside the dishwasher.
There is no reset on this model.
In the past, when the Cancel and Normal LEDs were flashing, I would let it sit for 48-72 hours and it would stop flashing the LEDs.
That hasn't worked this time.
Does anyone know what I should check to see what is causing the problem?
