Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
HI, I need help! Thermador Gas Range Model #PRG366EPG/04 everything works except the oven in Bake Mode. It lights once and then it won't light again. It works fine on Convection. It has 2 ignitors. Glow type and a Spark Type on the same burner. In Bake and convection setting, only the glow ignitor works(glows and lights the burner). I have never seen the spark ignitor spark. I tested it for continuity and it's fine. Could it be the Bake Solenoid?
