Rico
#1 Posted : Sunday, March 14, 2021 11:07:03 AM(UTC)
Guest
Rank: Guest
United States
HI, I need help!
Thermador Gas Range Model #PRG366EPG/04
everything works except the oven in Bake Mode. It lights once and then it won't light again. It works fine on Convection. It has 2 ignitors. Glow type and a Spark Type on the same burner. In Bake and convection setting, only the glow ignitor works(glows and lights the burner). I have never seen the spark ignitor spark. I tested it for continuity and it's fine. Could it be the Bake Solenoid?
Thermador gas range flames too high (Oven Repair (including Ranges and Cooktops))
by Sue24 8/30/2016 9:13:17 AM(UTC)
How to remove shredded venturi tube? (on thermador gas range) (Oven Repair (including Ranges and Cooktops))
by samjones4 12/16/2014 8:56:29 PM(UTC)
