My GE profile looks to not be filling up to the heating elements. I took the water valve off and cleaned out the mesh little basket. Re tried and it still does the same thing. Before buying a new water valve, what other things that can cause this? I feel like its not going thru its whole cycle either, the lid to the detergent wont open after a while either. If it doesn't fill up will it not run its full cycle?
Thanks in Advance!
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Don't know much about the GE dishwashers, but you could have an intermittent water valve. they have a coil that opens its windings when it gets warm. You could have a stuck overfill switch. Its attached to a float in the dishwasher and sometimes they get stuck up. You could have a restriction in the water coming in. Pinched water line or restricted water shutoff.
