Joined: 12/14/2020(UTC) Posts: 0  Location: British Columbia
I AM A HYBRID & E/V AUTO TRADESMAN... WIFES DRYER QUIT... ISOLATED FAULT TO THERMAL FUSE... REPLACED THERMAL FUSE(150C/10A) & HIGH LIMIT THERMOSTAT...CLEANED OUT EXCESSIVE LINT (LINT TRAP DEFORMED) FIXED. DRYER OUTSIDE VENT SCREEN WAS ALSO PLUGGED... FIXED RAN FOR 2 DAYS QUIT AGAIN (WHEN IN COOL DOWN CYCLE - CLOTHES STILL DAMP) TESTED BOTH HIGH LIMIT(L248) & CONTROL THERMOSTATS(L146)( FOR CONTINUITY & OPENING @ CORRECT TEMP... BOTH PASSED. TESTED HEATER ELEMENT... 11 OHMS - PASSED. HEATED ELEMENT NOT SHORTING TO HOUSING... CHECKED BLOWER WHEEL... SECURED CORRECTLY. MACHINE EXHAUST VENTING CLEAR... TESTED DOOR SWITCH... CONTINUITY & OPEN - PASSED FROM MY UNDERSTANDING THE THERMAL FUSE SHOULD BE A "LAST RESORT FUSE"... BUT BOTH HIGH LIMIT & CONTROL THERMOSTATS TEST OK... IS IT POSSIBLE MOTOR IS DRAWING TO MUCH CURRENT & BLOWING THE THERMAL FUSE DUE TO CURRENT? DOES THE MOTOR NOT HAVE ITS OWN "BUILT IN PROTECTION"(FUSE OR THERMAL SWITCH)??? DO YOU HAVE A SPEC FOR MOTOR DRAW/RESISTANCE TESTING?
THANKS IN ADVANCE!!!
