AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
(SOLVED) Amada (Whirlpool) ADB1100AWW3 intermittent spraying
Hello everyone. My washer will spray correctly in some cycles and not durring others. The filters, spray arms, and everything I can check are clear of blocks. I am suspecting that the control board has gone bad but I dont have the experience or Tools to check it. Could a faulty control board be a problem in this case? Thank you for reading and any help. Amada model ADB1100AWW3 Control board model W10817282 (I believe) Edited by user Saturday, December 19, 2020 9:41:07 AM(UTC)
| Reason: Not specified
Update for anyone wondering:
I did replace the control board. It was not the problem.
My next move was to remove and dissasemble the circulation pump. Once it was taken apart I found and removed a small amount of hair wrapped around the shaft of the impeller. The rest of the unit was fine.
I reinstalled the pump and as of now the washer is working. Hope it stays that way.
Dishwasher Repair
