Stackes
#1 Posted : Thursday, November 19, 2020 3:28:52 PM(UTC)
Stackes
Hello everyone.
My washer will spray correctly in some cycles and not durring others.
The filters, spray arms, and everything I can check are clear of blocks.
I am suspecting that the control board has gone bad but I dont have the experience or Tools to check it.
Could a faulty control board be a problem in this case?
Thank you for reading and any help.
Amada model ADB1100AWW3
Control board model W10817282 (I believe)
Edited by user Saturday, December 19, 2020 9:41:07 AM(UTC)  | Reason: Not specified
Stackes
#2 Posted : Saturday, December 19, 2020 9:40:17 AM(UTC)
Stackes
Update for anyone wondering:
I did replace the control board. It was not the problem.
My next move was to remove and dissasemble the circulation pump. Once it was taken apart I found and removed a small amount of hair wrapped around the shaft of the impeller. The rest of the unit was fine.
I reinstalled the pump and as of now the washer is working. Hope it stays that way.
