Hello all. Hoping for help with this problem.
Model: GE Profile Washer WPSR4130W1WW top-loader
Year: 1999
History: Low usage. Ten loads per year for first 18 years, two loads per week for last three years.
Symptom: Loud squeaking during agitation. Sounds like bearing. Eee-eee-eee-eee-eee. Rare, isolated chirps during spin on some days. All functions operate fine.
Actions taken and stuff learned: - I replaced belt with new OEM belt and cleaned both pulleys with alcohol and steel wool. No change in noise. - No noise when run with belt removed; assume motor unit ok. - Tub 3/8" lower on one side, but no noise change when leveled. - No metal shavings anywhere. - No pulley contact with anything during agitation. - Drive pulley may have 1/8" wobble visually, but not loose on shaft and nut tight. Little or no end play.
Thoughts on diagnosis? Thanks, Jeff
