RobStarz
#1 Posted : Sunday, October 18, 2020 2:25:51 PM(UTC)
RobStarz
Man
United States
When I turn the dryer on the igniter glows and I hear the gas valve open and see flame turn on. After 10-15 seconds it turns off and the ignitor dims. about 1 minute or 2 later it repeats and never stays lit. I have checked the thermister (and replace cause I thought it was the issue). Below is what I have checked.
Solenoids : ~1933hmz
Thermister: 9.32hmz
Hi and low: 0hmz
flame sensor: 0hmz
On my control panel the Check Filter symbol is lit but the filter is clean. I have taken all apart and there is nothing that is blocking the air movement. I have tested this also with the vent hose off just in case it is a clogged vent pipe.
What else can be wrong that this is happening?
i saw this video online and it is exactly what my dryer is doing.
Thanks in advance
Rob
