When I turn the dryer on the igniter glows and I hear the gas valve open and see flame turn on. After 10-15 seconds it turns off and the ignitor dims. about 1 minute or 2 later it repeats and never stays lit. I have checked the thermister (and replace cause I thought it was the issue). Below is what I have checked. Solenoids : ~1933hmz Thermister: 9.32hmz Hi and low: 0hmz flame sensor: 0hmz On my control panel the Check Filter symbol is lit but the filter is clean. I have taken all apart and there is nothing that is blocking the air movement. I have tested this also with the vent hose off just in case it is a clogged vent pipe. What else can be wrong that this is happening? i saw this video online and it is exactly what my dryer is doing. Thanks in advance Rob
