Hi there,
I have a whirlpool WRX735SDBM02 fridge. if I turn it on, it will be off in a couple of seconds, and then turn itself on, then off again, and again. the frequency of this cycle is around 2-3 seconds. It behaves like this for a few mins before it is completely off.
I already replaced the control board and the power board, however, the problem still persists. Today, I connected an external DC power supply to the output pins of the power board (14V), and the fridge is finally up and running.
It seems the fridge doesn't have enough current to start the running processes. When I start the fridge, the current draw from my DC power supply is like 7A for a couple of seconds. After it is up, the current draw from my DC power supply is close to zero.
any suggestions? do you think I should replace the compressor capacitor next?
thanks, Frank
