I have a GE Dishwasher (2015-2016 new), model number GSD3300D35BB. It will start, then a few seconds later will stop. If you push the GE logo (middle of door, below latch) it will start again. I have looked to see if there is anything impeding the door closing properly. Everything seems to go in properly with nothing blocking. The latch latches fully. There are 5 button: Pots & Pans, Normal Wash, Hi Temp Wash, Heated Dry, Reset Options. Normal Wash is lit. I have tried pushing Reset Options as well as holding it in for 3 seconds. I rigged a pole to continuously press in where the GE logo is and it did a full cycle. I am thinking door/latch, something electronically is detecting a problem with the door, something else electronically or something I am not thinking of. Any help would be greatly appreciated.
