AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag mhw5630 control panel swap with mhw6630 unlock Sanitize feature?
Joined: 6/28/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Minnesota
Bought the Maytag mhw5630 which has steam function but doesn’t have the sanitize option. Could I simply swap front control panels to “unlock” the sanitize feature or would I also need to swap the ACU unit (main control board)? I checked the part numbers of each unit and they do not share part number so I’m guessing I would need to swap both components. I can’t see any other hardware difference that would be a limiting factor, other than the two components ( acu & front control panel).
Not sure if anyone has done this?? Perhaps someone could weigh in with their opinion. Thanks in advance!
Washer Repair
