I have Modern Maid , double 24" oven. Model FDO180. can someone confirm whether the original element connection is soldered?... The recommended bake event replacement is a Whirlpool WP77001092. the replacement element comes with a male knife blade connection. Do I need to solder the mating connection on to the element wires? Is any solder okay for this, is the connector subject to getting hot? Edited by user Wednesday, April 22, 2020 4:35:53 PM(UTC)
| Reason: Not specified
