Joined: 4/22/2020(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: CALIFORNIA
I have Modern Maid , double 24" oven. Model FDO180. can someone confirm whether the original element connection is soldered?... The recommended bake event replacement is a Whirlpool WP77001092. the replacement element comes with a male knife blade connection. Do I need to solder the mating connection on to the element wires? Is any solder okay for this, is the connector subject to getting hot? ![wire connection wire connection](https://www.dropbox.com/s/w0yku89z0n8haj8/IMG_20200422_160513.jpg?dl=0) Edited by user Wednesday, April 22, 2020 4:35:53 PM(UTC)
| Reason: Not specified
