randjclifford
#1 Posted : Tuesday, March 31, 2020 4:58:27 PM(UTC)
randjclifford
United States
I have an old Maytag LAT3914AAE washer. The agitator is working intermittently and seems to get "stuck" which then is causing the motor to overheat and produce a burning smell. The switch seems to be working and I was able to test by taking a flat head screwdriver and activating the switch while keeping the lid open. That's how I was able to see that the agitator is only working sometimes. The washer seems to spin just fine on the spin cycle. I have recently replaced both the pump and drive belt. Please help me! I really, really don't want to buy a new washer!
brobriffin
#2 Posted : Tuesday, March 31, 2020 6:14:05 PM(UTC)
brobriffin
Man
United States
My first impression of your issue is a transmission problem. If this proves true you will need to replace it. We have it right here @
https://www.appliancepar...6-2097750-ap4373301.html
But you would be better off going new cause this is not cheap!
