Lillydz101
#1 Posted : Wednesday, August 14, 2019 8:59:05 PM(UTC)
Lillydz101
United States
My Electrolux dryer (model Eied55hiw0) only works on the air dry cycle. I was going to attempt to change out the thermal fuse to see if that fixed the issue. After disassembling the dryer, I realize the thermal fuse that is currently in the dryer does not look like the ones that say they are compatible. I don’t want to install the wrong type/part if it will hurt the dryer.
The one that is currently in the dryer resembles part # AP6009129
The one that is compatible is part # 134711401.
Do I have to get one that looks like the one I took out or the one that matches compatibility? And if I get the one that is compatible, does that mean I just install it flush to the tube? Thanks
Edited by user Wednesday, August 14, 2019 9:03:13 PM(UTC)  | Reason: Not specified
