cjd2404
#1 Posted : Tuesday, August 13, 2019 11:14:56 AM(UTC)
cjd2404
United States
I have a Kenmore Elite 795.787.53800 Fridge/Freezer. A few months ago the unit stopped dispensing water, but when I pushed the button in the front of the unit where water came out you'd hear the pump? or whatever it is running.
I replaced the inlet valve in the back of the fridge a few weeks ago and everything seemed fine. Last week no more water or ice will dispense and now pushing the button where the water comes out makes no sound at all. The ice maker also appears to not be getting power (the light on the ice maker itself for cube size or power are not lit).
I tried replacing the switch on top of the door on the water side, as well as the button in the freezer and neither of those helped. I figured maybe those went bad and it was acting as if the door was open. I only have a cheap continuity tester, but the valves in the door next to the water lines both have continuity
The front display panel works fine, the light will go on and the fridge/freezer are fine.
Any help would be appreciated.
Thanks!
Chris
