Gate-c
#1 Posted : Sunday, April 7, 2019 7:24:02 AM(UTC)
Gate-c
United States
Assuming the wobble in the drum is from broken spider I figured I might as well replace the bearing while everything is pulled apart, but I can’t seem to find reliable information if the WF337AAR/XAA bearings can be replaced or if there are built into the outer tub (DC97-12957A).
https://www.appliancepar...97-12957a-ap4210702.html
Does a new tub need to be purchased or can the bearings be replaced on this model? I don’t want to purchase a whole outer tub casing if I don’t have to if the bearings are not the issue.
Edited by user Sunday, April 7, 2019 7:26:43 AM(UTC)  | Reason: link to part
Gate-c
#2 Posted : Sunday, April 7, 2019 7:35:12 AM(UTC)
Gate-c
United States
I don’t want to purchase the outer tub casing if the bearings are not the issue.
Unsure if there was a slow progression of a wobble forming in the drum, just all of a sudden after a wash cycle there was smoke and melted rubber around the door seal. from friction. Spinning the empty drum by hand I could see there was an off-center wobble and rubbing.
I assumed the spider arm corroded and broke and no longer supported the drum property. I figured I would confirm one the washer was disassembled.
The spider does have some cracking, but the arms are still intact and trying to wiggle the shaft around I don’t notice any loose play. There is some oily rust along the base of the shaft. Is this a possible sign of the bearing goes bad? There wasn’t any significant grind sounds.
Spider shaft
Is the off center spin a good indicator of bad bearings or is it most likely the spider integrity being compromised?
