ibtrees
#1 Posted : Thursday, November 5, 2009 4:33:52 PM(UTC)
ibtrees
Our refrigerator was leaking water into the refrigerator part in the back. it has slowed down now. But now the freezer part looks like antartica and everything is frozen to hard. We have tried to turn the temp. down but it wont go down. What's could be wrong with it. Is it dying.
#2 Posted : Friday, November 6, 2009 4:37:19 AM(UTC)
Replacement parts for WHIRLPOOL ET1CHMXKT02 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%202225759.pdf
This sounds like your drain down to the drip tray under the unit is partially plugged.
Check that dust etc, is not plugging the tube under the unit at the drip tray.
Blow it clear from the top. Use a compressor. or a straw (piece of tubing) to blow into it or a turkey baster with some warm water.
Once you get it clear flush it with a 10% bleach solution to kill the crud that grows in the tube.
Check to see if the compressor is running.
Turn the temp to Off if the compressor does not go off then the contacts in the thermostat are welded together and you have to replace it.
Check that nothing is blocking the drain.
Unplug the unit. Remove the evaporator coil cover, check that nothing is blocking the drain in the freezer. Plug the unit in and turn the defrost timer till the unit goes into a defrost mode(fans will shut off). Check that the defrost heater comes on. Do not burn your fingers. Let it defrost. Unplug the unit, wipe the interior dry and check that all the ice is melted on the freezer floor/top of fridge. If not let it thaw before plugging the unit in again.
Give the unit a try. Would be a good idea to check the freezer temperature with a thermometer. Should be 0 to 5 degrees. If it goes lower and will not regulate I would replace the thermostat/temp control.
Is it dying.
No. It may just need a part. It is a nice simple unit so the repair should not be that difficult or expensive.
Here is a good site with troubleshooting help
http://www.applianceaid.com/frig.html
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
