One day the power went out and ever since my oven every so often shows code F7 and beeps. Now sometimes it will go a day and not beep at all and other times it beeps non stop. Can you tell me what the code means.
In order to provide the most accurate advise I need the complete model number and the color of the unit.
The complete model# is JCKP15BA2BB and is Black in color.
The "F7" error code means one or more pads on the key panel are stuck. The control panel has to be replaced in order to solve the problem. - The part number for the control panel is AP3185152 Here are the break down diagrams for the GE oven Model JCKP15BA2BBGene.
