ecamn
#1 Posted : Saturday, June 16, 2018 9:34:31 PM(UTC)
ecamn
I have an old Kenmore Elite gas dryer which a couple of weeks ago stopped heating. It starts and the drum spins, but no heat. I also don't see the igniter glowing. I checked using a multimeter the usual suspects --- igniter, thermal fuse, gas valve solenoid, flame sensor, power supply, high limit thermostat, thermistor, timer and motor, and the values of resistance (for continuity) are within the expected values or range. I also tested using both timed dry and the automatic setting, but both showed the same problem. The power supply is at 110V, and I also checked the circuit breaker but not sure if for my gas dryer model, I should also see some 240V circuit. I'm not an expert but I've read a lot of posts. I appreciate if someone can point me in the right direction. Thank you.
