Seagen43
#1 Posted : Friday, March 2, 2018 1:57:18 PM(UTC)
Seagen43
Hello! We just moved a few days ago. Hooked up the dryer last night (brought it with us from previous home) and the timer doesn’t move and there is no heat. Dryer worked perfectly fine at out last home.
ThatGuy
#2 Posted : Friday, March 2, 2018 2:40:19 PM(UTC)
ThatGuy
Groups: Expert
United States
Check the plugin and terminals where the cord hooks on to the dryer.
You should have 240 volts across the outside terminals and 120 volts AC from either one to the center terminal.
ThatGuy attached the following image(s):
microwave turns on automatically, no timer, no heat (Microwave Repair)
by Michael Nguyen 4/8/2009 6:51:35 AM(UTC)
