Uline Icemaker needs new Icemaker assembly. Can I replace with a different brand of Icemaker. Uline plug has 5 wires(red, black, white, yellow, brown) and the new unit has 4 wires( black, green, yellow and blue). Any ideas on how to connect wires
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
I found this manual, it has a wiring diagram. I don't know if it's the same as yours but it might help. Apparently the extra wires have to do with the bin switch and some different wiring inside. It would take a bunch of rewiring and an ice maker that is very close to the old one. http://www.u-line.com/userguide...U-BI95B-00A/?___store=us
