wpollock
#1 Posted : Saturday, January 6, 2018 8:27:41 AM(UTC)
wpollock
Unit has power as evidenced by interior light,touch pad control and timer working.However turntable will not turn and magnetron will not energize. Magnetron was replaced within last 4 months.
Any thoughts as to issue and how I can test to isolate are appreciated.
wpollock
#2 Posted : Saturday, January 6, 2018 10:23:02 AM(UTC)
wpollock
Need to revise my post. I tried to run the unit again and had the following results: First cycle I applied slight pressure to the pad that opens the door until the unit started to run then released the pressure on the door pad and the unit ran to cycle end. Second cycle the unit ran after applying pressure to the door pad and then releasing like in first cycle and when I stopped it during the cycle it continued to run even with the door open. Third cycle the unit would only run with constant slight pressure on the door pad. Last cycle the unit would not run even with constant and slight pressure on door pad. Unit still has power
#3 Posted : Monday, January 8, 2018 9:11:22 PM(UTC)
Check the door interlock switches (#3 top and bottom on the diagram) for continuity.
The door interlock switch kit Part number: AP3109474
Here are the breakdown diagrams for Model KCMS2055SSS1
Unit Not Turning On (Microwave Repair)
by wpollock 7/12/2018 5:24:42 PM(UTC)
