Installed in cabinet above matching wall oven.
Door switches replaced in March 2018
Unit has power as evidenced by key pad illuminated and interior light coming on/going off when unit is plugged in and door is opened/closed
I would like to test the switches(3 post I believe) for continuity and then continue from there
I have removed the trim kit,loosened the base mounting bracket and unplugged the unit. Can someone tell me how to open the cover and access the switches?
Also,if the switches test good what should I test next?
Thanks for any replies
Have you looked at the fuses? Years ago, mine had no power and took it out, unscrewed the top to get a look inside and it turned out one of the fuses was fried. got a new one at radio shack, wired on a new connector and viola. Worked again.
