My igniter will not glow.
I replaced the igniter, thermal fuse, and thermostat.
I checked the ohm's on all the other sensors and they are good. It appears that my thermal sensor and thermostat was good as well.
When I replaced the thermal fuse and thermostat I ran the dryer without the drum, I assume that would be okay. If not, let me know.
What else could it be?
Thanks in advance.
Can the solenoids continuity affect the igniter glowing?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Groups: Expert
I forgot to mention the motor switch has to be closed too, Also going back to the neutral wire.
