swatosh
#1 Posted : Friday, December 29, 2017 8:33:50 AM(UTC)
swatosh
My igniter will not glow.
I replaced the igniter, thermal fuse, and thermostat.
I checked the ohm's on all the other sensors and they are good. It appears that my thermal sensor and thermostat was good as well.
When I replaced the thermal fuse and thermostat I ran the dryer without the drum, I assume that would be okay. If not, let me know.
What else could it be?
Thanks in advance.
swatosh
#2 Posted : Friday, December 29, 2017 8:53:16 AM(UTC)
swatosh
Can the solenoids continuity affect the igniter glowing?
ThatGuy
#3 Posted : Friday, December 29, 2017 2:30:01 PM(UTC)
ThatGuy
Groups: Expert
United States
You need to follow the voltage from line in through the timer, the temp. selector switch, to the thermostat to the safety thermostat to the air inlet control thermostat then to the ignitor and the sensor then to the neutral (white) .
Something is stopping the power.
Parts for Maytag HYG3657AWW: Wiring Information (series 13) Parts - AppliancePartsPros.com
ThatGuy
#4 Posted : Friday, December 29, 2017 3:23:32 PM(UTC)
ThatGuy
Groups: Expert
United States
I forgot to mention the motor switch has to be closed too, Also going back to the neutral wire.
Amana gas dryer igniter won't glow (Dryer Repair)
by MarvinAllred 1/25/2011 5:56:10 AM(UTC)
