Gixxer527
#1 Posted : Thursday, November 9, 2017 3:16:04 PM(UTC)
Gixxer527
Hello everyone, I have a kenmore front loading coin op washer which doesn't change cycles. I can start the washer, it will start for a few seconds then stop. If I manually move the timer to the next cycle it will add water and work until it needs to switch to next cycle. Then it stops, I then manually move timer and it will perform next cycle and stop.
I've tried front door switch, checked the inlet valve and drain pump prior to moving timer manually. I then tried another timer which when it started it did add water and went to next cycle but stopped. If I move it manually it will finish cycle and stop.
Any help would be greatly appreciated
Thank you
Kenmore Front Loading Washer Won't Drain (Washer Repair)
by MariaD 9/27/2012 9:11:56 AM(UTC)
kenmore front loading washer (Washer Repair)
by stcrider65 5/24/2011 6:13:24 PM(UTC)
Kenmore Front Loading Washer (Washer Repair)
by ANDREA1 4/28/2011 10:04:50 AM(UTC)
Kenmore front loading washer won't drain (Washer Repair)
by vince123 5/13/2009 5:08:13 AM(UTC)
Kenmore front loading washer noisy (Washer Repair)
by bobbiraej 1/20/2009 7:31:36 PM(UTC)
