Hello everyone, I have a kenmore front loading coin op washer which doesn't change cycles. I can start the washer, it will start for a few seconds then stop. If I manually move the timer to the next cycle it will add water and work until it needs to switch to next cycle. Then it stops, I then manually move timer and it will perform next cycle and stop.
I've tried front door switch, checked the inlet valve and drain pump prior to moving timer manually. I then tried another timer which when it started it did add water and went to next cycle but stopped. If I move it manually it will finish cycle and stop.
Any help would be greatly appreciated
Thank you
