tombeird
#1 Posted : Wednesday, November 8, 2017 2:32:42 PM(UTC)
tombeird
maytag gas dryer initially was running hot but worked. then began to heat only intermitently and now runs continuously but applies no heat at all. drum spins. igniter does not glow and there is no flame. dryer spins and wont shut off. the thermostats, all switches and sensors test out ok. there is no clog in the vent system. cleaned off the motor centrifugal switch contacts. still without change.what can be wrong here?
ThatGuy
#2 Posted : Wednesday, November 8, 2017 4:25:41 PM(UTC)
ThatGuy
Groups: Expert
United States
Do you have 120 VAC at the igniter? If not you need to work back through it to find what is stopping the voltage.
tombeird
#3 Posted : Monday, November 13, 2017 5:01:31 PM(UTC)
tombeird
i do not but thank you for pointing that out
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
LG gas dryer no heat (Dryer Repair)
by Guest 8/15/2021 10:28:45 AM(UTC)
Whirlpool gas dryer no heat (Dryer Repair)
by alabamainnevada@yahoo.com 6/23/2015 5:54:15 PM(UTC)
Gas Dryer NO HEAT/FLAME and possible bad timer? (Dryer Repair)
by noles9399 2/26/2015 10:12:14 PM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Hotpoint gas dryer no heat (Dryer Repair)
by Erich4130 8/28/2013 3:45:28 PM(UTC)
by huggard42 5/30/2013 4:34:58 PM(UTC)
Gas Dryer No Heat (Dryer Repair)
by AkZipper 11/29/2012 4:14:41 AM(UTC)
ge gas dryer no heat (Dryer Repair)
by mdelgiu1 11/7/2012 1:23:14 AM(UTC)
Ge gas dryer no heat (Dryer Repair)
by moby2000 10/25/2012 9:04:28 AM(UTC)
Kenmore Gas Dryer No heat (Dryer Repair)
by Resultsnow 9/8/2012 11:14:56 AM(UTC)
Gas dryer no heat (Dryer Repair)
by Brent gordon 7/31/2012 1:36:06 PM(UTC)
by petec357 6/21/2012 3:05:37 AM(UTC)
Frigidaire gas dryer no heat (Dryer Repair)
by mbarone 3/18/2012 4:25:38 PM(UTC)
my whirlpool gas dryer no heat and wont shut off (Dryer Repair)
by phyllisl 3/8/2012 6:13:19 AM(UTC)
