Hello Parts Pros,
My Atlantis would not run. All power to unit checked out and after reading a few posts here I bypassed the lid switch with a jumper to the red, yellow and black wires. The washer turned on and filled with water. Yay, I thought for sure it was fixed. Problem is that it filled with water and that was it. No nothing after that. No agitation, no motor humming, nothing. Now I have a tub full of water and don't know what to do? Could it still be the lid switch? I'm perplexed...
Originally Posted by: Bsktbll  Hello Parts Pros,
My Atlantis would not run. All power to unit checked out and after reading a few posts here I bypassed the lid switch with a jumper to the red, yellow and black wires. The washer turned on and filled with water. Yay, I thought for sure it was fixed. Problem is that it filled with water and that was it. No nothing after that. No agitation, no motor humming, nothing. Now I have a tub full of water and don't know what to do? Could it still be the lid switch? I'm perplexed... Well guys, it appears it was the lid switch after all. Seems that the power circuit was tripped after the washer started filling with water. I Reset the circuit breaker and now washer is functioning. Yay....and thanks anyway
