sojrnr6
#1 Posted : Monday, February 18, 2008 11:50:44 PM(UTC)
sojrnr6
oven does not heat up at any temperture. there is power. the front control panel light is out. so i can't tell the setting. i was thinking of ordering a new clock control panel,which show the temperture setting and see if that works.hope to hear from the forum soon .having company over next week!
#2 Posted : Tuesday, February 19, 2008 5:15:31 PM(UTC)
Did it click when you touched any pads?
Did you check the circuit breakers?
I need you to answer on these questions before we go further.
Frigidaire - Oven will not heat up but burners work (Oven Repair (including Ranges and Cooktops))
by JohnGuerra 3/18/2020 12:45:12 PM(UTC)
Double Wall Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jwmingus 11/12/2013 4:25:40 PM(UTC)
My Oven will not heat up on bake (Oven Repair (including Ranges and Cooktops))
by missy79 4/3/2013 9:59:06 AM(UTC)
Maytag Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by debost 1/16/2013 9:46:49 AM(UTC)
Whirlpool Gas Oven will not heat up to desired temperature. (Oven Repair (including Ranges and Cooktops))
by captjob 7/29/2012 5:45:19 PM(UTC)
Double Oven will not heat up past "LOW" (Oven Repair (including Ranges and Cooktops))
by jnichols_1967 2/6/2012 7:52:56 AM(UTC)
Whirlpool Oven will not heat up (Oven Repair (including Ranges and Cooktops))
by stgdobber 5/3/2011 11:19:32 AM(UTC)
Fridgedaire gas range-oven will not heat up (Oven Repair (including Ranges and Cooktops))
by ccjden 3/17/2011 9:52:26 AM(UTC)
by casey114 12/16/2010 11:57:59 AM(UTC)
KitchenAid oven will not heat up... replace thermostat? (Oven Repair (including Ranges and Cooktops))
by Matt M 12/7/2010 11:42:49 AM(UTC)
Oven will not heat up, gas won't flow (Oven Repair (including Ranges and Cooktops))
by spystyle 11/23/2010 3:57:13 PM(UTC)
by hitman401 11/1/2010 1:16:19 PM(UTC)
Dacor Epicure oven will not heat up (Oven Repair (including Ranges and Cooktops))
by jeab 8/10/2010 11:46:30 AM(UTC)
by ar.muncy 3/17/2010 8:47:54 AM(UTC)
Gas Jenn-Air oven will not heat up? (Oven Repair (including Ranges and Cooktops))
Belarus Tony3 12/17/2009 8:04:58 AM(UTC)
