while replacing the broiler element the wires touched together and sparked. I had to replace the end of one of the wires. The broiler works but the bake element doesn't. I then replaced the bake element it still doesn't work. All the wires look to be good and in tact. What else could the problem be. Thank you for any help
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 ![United States United States](/Content/images/flags/US.png) Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
You probably damaged the main board. I checked a couple of places and they are no longer available.
everything else works except the bake element. If the main board was damaged it would seem like other things wouldn't work. Is that not the case?
Groups: Expert
