cpolk
#1 Posted : Friday, October 6, 2017 7:35:11 AM(UTC)
cpolk
while replacing the broiler element the wires touched together and sparked. I had to replace the end of one of the wires. The broiler works but the bake element doesn't. I then replaced the bake element it still doesn't work. All the wires look to be good and in tact. What else could the problem be. Thank you for any help
ThatGuy
#2 Posted : Friday, October 6, 2017 2:09:06 PM(UTC)
ThatGuy
Groups: Expert
United States
You probably damaged the main board. I checked a couple of places and they are no longer available.
cpolk
#3 Posted : Friday, October 6, 2017 3:55:15 PM(UTC)
cpolk
everything else works except the bake element. If the main board was damaged it would seem like other things wouldn't work. Is that not the case?
ThatGuy
#4 Posted : Friday, October 6, 2017 11:34:35 PM(UTC)
ThatGuy
Groups: Expert
United States
Go to the main board check for continuity through the bake element back to the board. If that tests OK, check for 240 volts AC across the element when it should be heating.
Wiring diagram.
Parts for Frigidaire FEF377CFBE: Wiring Diagram Parts - AppliancePartsPros.com
cpolk
#5 Posted : Saturday, October 7, 2017 10:20:35 AM(UTC)
cpolk
ok thank you very much
Frigidaire oven diagram control board (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2024 10:28:10 AM(UTC)
Frigidaire Oven Heats but Randomly Shuts off (Oven Repair (including Ranges and Cooktops))
by Guest 10/1/2022 7:32:55 AM(UTC)
Frigidaire oven won't stay lit (Oven Repair (including Ranges and Cooktops))
by Guest 7/31/2022 6:36:11 PM(UTC)
Frigidaire oven door hinge not locking (Oven Repair (including Ranges and Cooktops))
by jacobrobbins219 3/16/2021 5:42:08 PM(UTC)
Frigidaire Oven Preheats, but doesn't keep heat (Oven Repair (including Ranges and Cooktops))
by ben99 12/16/2020 12:49:23 PM(UTC)
My Frigidaire oven doesn't hold temperature in bake mode but does in convection mode (Oven Repair (including Ranges and Cooktops))
by rph812 8/24/2020 3:25:59 PM(UTC)
Frigidaire oven element (Oven Repair (including Ranges and Cooktops))
by Rhauck 5/24/2020 3:32:51 PM(UTC)
FPEH3077RFC - Frigidaire Oven Intermittent Temperature Issues (Oven Repair (including Ranges and Cooktops))
by pahey 1/15/2020 4:06:14 PM(UTC)
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
Frigidaire oven inoperable (Oven Repair (including Ranges and Cooktops))
by imabeanct@aol.com 1/31/2018 7:52:02 AM(UTC)
Frigidaire Oven bake option not working Igniter won't light (Oven Repair (including Ranges and Cooktops))
by mlb7412 9/30/2016 7:02:20 AM(UTC)
New Frigidaire oven Control Panel/Board - wiring help (Oven Repair (including Ranges and Cooktops))
by IGoofed 11/16/2015 8:06:12 PM(UTC)
Frigidaire oven - bake and broil elements not working (Oven Repair (including Ranges and Cooktops))
by wife2004 9/21/2015 5:51:02 PM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Frigidaire Oven Not Heating (Oven Repair (including Ranges and Cooktops))
by etybor 2/9/2015 7:15:48 AM(UTC)
