DonTaylor
#1 Posted : Sunday, September 24, 2017 6:13:49 AM(UTC)
DonTaylor
A friend gave us a Jenn Air model FCE30610W flat top range. The clock works and the panel lights works. The burners do not heat when turned on. The oven does not heat. You can set the temp, it clicks and acts like it's going to start heating. It shows a temp of 100* but does not heat any further. Any ideas?
ThatGuy
#2 Posted : Monday, September 25, 2017 9:44:49 PM(UTC)
ThatGuy
Groups: Expert
Are you sure you have 240 volts to it? Sounds like you are missing 120 volts.
Parts for Jenn-Air FCE30610W: Wiring Information Parts - AppliancePartsPros.com
Jenn Air Range Burner HOT (Oven Repair (including Ranges and Cooktops))
by agdodge4x4 1/19/2016 4:48:15 PM(UTC)
Jenn Air Range/Convection oven won't bake or broil (Oven Repair (including Ranges and Cooktops))
by Pamwest 11/30/2015 11:09:20 AM(UTC)
keypad Jenn Air Range (Oven Repair (including Ranges and Cooktops))
by Teacher Jim 6/18/2015 9:44:08 AM(UTC)
Jenn Air Range Cooktop Hot Indicator Stays On For Hours (Oven Repair (including Ranges and Cooktops))
by beachbreeze 4/1/2013 8:47:30 AM(UTC)
by Loopy 8/30/2012 10:24:46 AM(UTC)
by Loopy 8/30/2012 8:45:42 AM(UTC)
FC error code on Jenn Air range (Oven Repair (including Ranges and Cooktops))
by jayjohn 6/20/2012 8:16:41 AM(UTC)
Replace burner control of Jenn Air range (Oven Repair (including Ranges and Cooktops))
by guy39 10/5/2009 5:15:46 AM(UTC)
FC Error on Jenn Air range (Oven Repair (including Ranges and Cooktops))
by prichardh 5/11/2009 10:00:38 AM(UTC)
Jenn air range glass cooktop replacement (Oven Repair (including Ranges and Cooktops))
by santostefano 4/21/2009 2:10:56 PM(UTC)
Older Jenn Air Range Fan Switch Replace--How To?? (Oven Repair (including Ranges and Cooktops))
by ibjessa 4/3/2009 12:10:14 AM(UTC)
jenn air range (Oven Repair (including Ranges and Cooktops))
by kkillian 3/14/2009 9:34:56 AM(UTC)
by ed wilson 10/2/2008 6:49:05 AM(UTC)
Jenn Air range error code F1-8 when hot (Oven Repair (including Ranges and Cooktops))
by JimSimpson 9/24/2008 6:19:30 PM(UTC)
no gas flow on Jenn Air range (Oven Repair (including Ranges and Cooktops))
by czrider 8/23/2008 2:56:31 PM(UTC)
